Piston & Barrel Is this scored?
Discussion in 'The Workshop' started by CZYNRG, Dec 28, 2008.
  1. CZYNRG
    CZYNRG New Member
    ? Thanks
  2. nibbles
    nibbles Active Member
    very slightly but will still run fine maybe put some new rings in and take it easy for a few miles
  3. capri dave
    capri dave Active Member
    difficult to say from photos, but ive seen a lot worse than that, from what
    i can see...
    As nibbles suggested, throw some new rings at it at least ;)
  4. CZYNRG
    CZYNRG New Member
    Yeah i'm gunna do, The piston rings can wear down without snappin causing loss of compression cant they? Just if this aint the problem with my scooter am shafted to know what it is lol!
    thanks x
  5. bertie
    bertie Active Member
    '93 Skipper LX125
    Just looks worn out
  6. numanoid1704
    numanoid1704 New Member
    r
    yes your rings can wear without snapping causing loss of compression.cant really tell from the photos but it looks worn not knackered.new rings would be good.you might as well as its in bits now anyway
  7. greg531
    greg531 Member
    If you can feel the scores with your fingernail, you need to go oversize....
    If not, I would get someone who know how to, lightly hone it, and then put in new rings....you already got it apart, and rings don't cost much, either will honing it....
  8. bertie
    '93 Skipper LX125
    Might aswell bang a 70's on it. Or one of the sport 50 kits, I wouldnt bother mucking about with worn parts, its only a matter of time before the cylinder plating wears away, can see abit of wear in the photos already.
  9. CZYNRG
    CZYNRG New Member
    Chucked new rings at it, It started once then just died after that!
    So looks like im after a 70 :)
  10. Vesta
    Vesta New Member
    Barrel wasn't scored i was there today doing his rings but the spark is weak and very temperamental thats your problem cozi (Y)
  11. waxhead
    waxhead Member
    Gee mate you may as well throw on a bb 86cc mhr kit since your in there
  12. Vesta
    Vesta New Member
    piss off you nonce
  13. RY4N172
    RY4N172 New Member
    :w00t:
  14. waxhead
    waxhead Member
    Whats a nonce
  15. RY4N172
    RY4N172 New Member
    a sex offender or child sexual abuser
  16. waxhead
    waxhead Member
    What the fuck
    Where is every ones sense of humour ???
  17. Kieran
    Kieran Active Member
    st
    Pressing F5 feels refreshing.
  18. MiNoR cOnFuSiOn
    now now vesta. hardly called for.
    as for the barrel, if you can feel the marks its damaged if not its usually fine. why not just use a better kit tho?
  19. CZYNRG
    CZYNRG New Member
    Tight budget
  20. Vesta
    Vesta New Member
    need to concentrate on getting the ignition sorted first coz
