PIPE CUTTING OUT !!!!!!!
Discussion in 'The Workshop' started by CA Zip tuning, Apr 8, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    Just put my pipe back on, i start it up it cuts out within 1 second of me starting it up. Where its attached to my cyclinder could the spacer be upside down because one of the bolts is lop sided there, help urgent !!! thanks
  2. roxy boy
    roxy boy Well-Known Member
    roxi
    have you changed the pipe or is it the same pipe
  3. CA Zip tuning
    same pipe when i put it back on i just put it in the cylinder hole and done up the bolts
  4. roxy boy
    roxi
    make sure there is no blockages in the pipe have you got an air compressor?
  5. ramo
    ramo GoldMember
    Do you mean the gasket? Usually they can go either way.
    Just make sure its on tightly and not leaking or anything. You should be able to start it without the pipe on tho really
    And might be worth putting a good condition bolt now before it snaps/strips etc
    roxy boy likes this.
  6. roxy boy
    roxi
    yes aslong as it seals it dosent matter
  7. oliwest
    oliwest Member
    aerox road legal pit
    Did you make sure there was no rust remover left in the pipe an the packing?
  8. roxy boy
    roxi
    make sure there is no shite in the pipe with air or somthing and try that....take the end can off and pour a pint of petrol down the pipe and seal both ends and shake it around...the fact that it starts then cuts out makes me think that the excess gases cannot escape and is choking the engine
