piggy zip 50 head light and rear light not working and bulbs on clock to say there on not working ...and also it was running and then cut out and now theres no spark .im thinking stator but im wondering if you can think of anything else iv tried new cdi new cap and lead and im not getting a spark even from the lead
its not the plug the cap the cable the cdi as iv swapped all of them out brand new battery aswell and the indis work fuel light works and oil light works just not the headlight light on clocks and headlight rear and break lights dont work im thinkin almost deffo stator but seems strange coz it was in ded good nick and work for 20 odd mins then just cut ut and wouldnt spark after
have a look over the bike, i had trouble with lights when i started the bike they were on but when i rode it they went off. It baffled me so i stripped the ped back and it turnt out to be some wires had been damaged something i would never have thought to be the problem, strip the bike, check your electrics wires, fuses and so on.
i need a wiring loom for my speedfight 2 100cc i cant see any on ebay unless im looking wrong, but if any 1 knows a website or any were to get 1 cheers or the connectors that u push in the bulb, ive tryed other things nothing works
Well on aeroxs i know that the yellow/re wire is for the lights front and back , and the rst run of the battery. Then the white one i power i think , so yea sound like a stator plate if it is not the wiring .
cant see it beeing the stator. checked all earth points?fuses? check all connection blocks for corrosion etc...
