Hi guys, Im after a photo of a giannelli reverse exhaust fitted to a piaggio 50/70 engine (like mine).... I need to see where the mounts etc go.....and how much room ill have to play with.... much appreciated!
isnt that an aerox? ill have a squize... but i want to see how its mounted on a piaggio.... basically, they dont sell a reverse intended for an ET2... the ET2 engines are used on other scoots..... so i want to see how much room they take up, and how they are mounted etc.....
cool man.... thanks.... ill have a squize.... i just need to work out how much modding is needed to get it to fit....
oh... cool... how did you do that? not 100% sure which other piaggio scoots have the same engine as mine... i keep forgetting if mine is a marrinelli (spelling) or what?
wooo....NRG.... like this.... http://www.youtube.com/watch?v=AUHJkchWH8c is that how the mounting brackets come?
ye the reverse has a 2 peice bracket.. never had probs with mine in the past but friends brackets have snapped.. i put this down to doing them up too tight tho.
look at mine i think my is the reverse nah mine never snapped either just bolts came loos a cuople off times but screwed back in!!
Thanks guys.... looks promising.... do you reckon they will on of them will fit here: Edit: btw there is supposed to be a 10cm ish wide piece of plastic that goes on there.... but i dont mind ditching it or making something else to put there.
