Piaggio zip violant rear end rattle!
Discussion in 'The Workshop' started by Nickzip50, Apr 3, 2013.
  1. Nickzip50
    Nickzip50 Member
    Hi guys, my ped rattles like hell when your riding and when you rev it hard, it also makes a very quiet rattling when it's on idle.
    It sounds as though it's comig from the gearbox?
    Any ideas?
    Also my old engine had a variator with much smaller rollers In? The variator was the right size for the rollers so it wasn't wrong but do you think it had been changed for a sporty one?
    Cheers
  2. Jonathan123321
    Jonathan123321 Member
    Piaggio NRG Power DD
    change your rollers and make sure everything is all tightened up. your variator bolt has proberly came loose. Check that first as its a very easy job !
  3. Nickzip50
    Nickzip50 Member
    Changed me rollers mate everything is tight
  4. steveaerox50
    steveaerox50 aprilia owner
    1999 aprilia rs125
    are you sure it's coming from the gear box and not the top end , could be small end bearing rattle
  5. Jonathan123321
    yeah it could be a loose crankshaft or broken bearings. On a two stroke sometimes its hard to pinpoint where the noise is coming from. If its a loud rattling noise i doubt its the clutch, its probably the crank.
  6. Nickzip50
    Nickzip50 Member
    It can't be the crank or the little end because it's not a consistent nock, it's a every couple of seconds loud or quiet tap, sometimes it doesn't do it sometimes it does or maybe I just don't notice it? Still runs brilliant
    I'm sure it's the gearbox because I revved it and stuck my head right againsy it's defo gearbox
  7. steveaerox50
    1999 aprilia rs125
    small end = rattle , big end = knocking , doubt it would be the clutch rattling , maybe the gear box bearings could need replacing
  8. steveaerox50
    1999 aprilia rs125
    or the belt maybe worn to the point where is slapping off the tranny case
  9. Nickzip50
    Nickzip50 Member
    I'm gonna hope it's just gearbox bearings. I'm sure that's all it was? To me it sounds like chipped teeth going round.
    Because it was running with practically no gearbox oil until I heard it and filled it up
  10. Nickzip50
    Nickzip50 Member
    Also has brand new mallosi belt
  11. Stig
    Stig Well-Known Member
    EXUP1000
    if its doing it on idle without the wheel moving then it wont be the gearbox
  12. Nickzip50
    Nickzip50 Member
    Well on idle the back wheel spins a bit
  13. steveaerox50
    1999 aprilia rs125
    hold the back brake to stop the wheel from spinning does it still do it
  14. Nickzip50
    Nickzip50 Member
  15. Nickzip50
    Nickzip50 Member
    When it's on idle and the back wheels spinning it's a very rare sound, like once every 5 seconds
  16. steveaerox50
    1999 aprilia rs125
    is the clutch bell tight
  17. Nickzip50
    Nickzip50 Member
    Yeah so right I can't get it undone lol only other thing I can think of is a warped clutch bell
  18. steveaerox50
    1999 aprilia rs125
    so is it a rattle or a knocking sound ? and which side of the transmission case is it coming from when you installed the rollers did you make sure not come out of the variator when sliding it on the crank , also did you remember to take the slack out of the drive belt
  19. Nickzip50
    Nickzip50 Member
    It's a rattle,and it's coming from the cover side, and yes I was careful with installation, and took slack out yes
  20. Stig
    EXUP1000
    any play in the rear wheel? it may be a bearing thats on its way out...they click like a push bike pedal crank sometimes
