piaggio zip uprated brakes
Discussion in 'Scooter Tuning' started by bulliporker, Apr 2, 2013.
  1. bulliporker
    bulliporker Member
    has anyone used the stage 6 caliper adapter to enable you to fit the stage 6 r/t 4 piston brake caliper
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Look on the zip sp under projects
  3. bulliporker
    bulliporker Member
    yes i have seen the petit pest adapter but at £100 just for the adapter and 4 spacers what are no use to me on my zip as i cant fit a bigger disc, and then it need additional machine work to enable it to clear the speedo cable it just seems to expensive, as i can buy the stage 6 caliper and adapter for hardly any more money , does anyone know what advantage has the petit pest adapter have over the stage 6 one
  4. MiNoR cOnFuSiOn
    wavey rear runner disc go's on the front of a zip... renew your caliper (new pistons and seals) and buy a decent brake line... will have an incredible brake wihtout the need for big diameter. if your brakes are shit its usually poor condition/brake line (the brake lines on scoots are so shit its untrue, get a braided one) check the projects for abz zip183.. had a similar setup on it
