piaggio zip sp
Discussion in 'The Workshop' started by Rideout93, Nov 13, 2011.
  1. Rideout93
    Rideout93 Member
    Zip zp 50
    hey guys.. Right few questions!
    When my paiggio zip sp 2003 starts up it rides normally.. 5mions later it seem tos bog out asif the choke was on? Staving itself from fuel? What can this be
  2. oliwest
    oliwest Member
    aerox road legal pit
    jetting or could need a new choke?
  3. Rideout93
    Rideout93 Member
    Zip zp 50
    Hmmm i cleaned the carb! now i judt dunno.. what size jet will i need?
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    Specs of bike ?
  5. Rideout93
    Rideout93 Member
    Zip zp 50
    Completely standard just de restricted i think? I know the exhaust is but the air box has the brass plate in? havent check variator?
  6. Jonnymarrw00t
    Replace the choke.
  7. Rideout93
    Rideout93 Member
    Zip zp 50
    Dont think it will be anything else?
  8. stkflote
    stkflote Member
    zip 2t cat
    check fuel tap is working correctly,if you take fuel pipe off carb and petrolcomes ,it your tap causing problem,
    this was same on neighbours scoot
  9. Rideout93
    Rideout93 Member
    Zip zp 50
    i took the pipe off the carb and fuel pisses out so i gather thats ok! I'm going to order main jet and choke
  10. stkflote
    stkflote Member
    zip 2t cat
    if fuel pissing out when pipes off, the taps knackered change it, thats your problem
  11. Rideout93
    Rideout93 Member
    Zip zp 50
    like if i took the the hose off the carb fuel judt drains out?
  12. Jonnymarrw00t
    Yeah. If it poors a little bit out and then it stops it's fine as it works on a vacume.
  13. stkflote
    stkflote Member
    zip 2t cat
    if it keeps coming out its nackered
  14. Rideout93
    Rideout93 Member
    Zip zp 50
    just keeps coming! :L ordered one.. be here tomorrow ;)
  15. Rideout93
    Rideout93 Member
    Zip zp 50
    Cheers guys for all your help! :) runs alot better now! there was a gap in the air bix! was getting too much air!
