My zip sp ran fine before i Washed it, but after being washed started straight away and ran for at least 5 minutes fine then turned off and put it yhr garage for a hour anf then back out the garage to go out got from my house half way up my street and it cut out and wouldn't start again tried new plug and plug cap all electrics be blown out cannot get a spark and when i do it is a faint white xolour spark not a strong blue one any idea really struggling
electrics got fucked??? how is that even possible??? are you running without a filter?? maybe water went in the carb somehow...
Tried coil and cdi with volt meter all reading fine and running standard air box so thats what is confusing me
hm....somehow the water went in the engine as i think... nothing else could be the problem i suppose.. check you carb manifold check if it is snapped..
so its running fine now?? lol water must have gone threw the exhaust... but its impossible if its a two stroke
no it has nothing to do with the carb and water not making it run right i cant get a spark the carb doesn't effect the spark need info on about getting a spark not running it mate
