piaggio zip sp headlamps
Discussion in 'General Scooter Discussion' started by bulliporker, Aug 17, 2012.
  1. bulliporker
    bulliporker Member
    anyone fitted higher wattage bulbs or hid kit or done anything to improve them as mine are crap
  2. Stathis
    Nrg Power 70cc
    if you put higher wattage bulbs they will keep blowing?? i think.. and if its a two stroke i find it hard to put a full HID kit on.. since 2 strokes dont have steady lights..
  3. bulliporker
    bulliporker Member
    there must be some way of improving the lights , compared to my vespa t5 they are terrible , why would they keep blowing ? if i replace most of the bulbs with led bulbs could i uprate the headlamp bulbs to 25/30 watt per side or is the wiring not up to it ,
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    the maximum wattage a zip headlight can take is 35 watts. anymore it'll just keep blowing the bulb.
  5. bulliporker
    bulliporker Member
    this is on a mk1 zip at the moment it has 2 15 watt bulbs what are like candles
  6. Edgar
    Edgar Active Member
    if you put a halogen light kit it will work as it connects to the battery and to your light beam which will make your light steady and very bright :)
  7. bulliporker
    bulliporker Member
    edgar do you mean a halogen bulb because i cant seem to find a hid kit for p26s bulbs and they are all 35watt which on a mk1 zip i would have 70watts of drain of the battery just with the headlamps alone
  8. Edgar
    Edgar Active Member
    im talking about full halogen hd lights that come in a set
  9. bulliporker
    bulliporker Member
    they dont seem to do them for p26s bulb fitment plus all hd headlamps use 35watt at start up if you have seen them could d you post a link
