Piaggio zip help please
Discussion in 'General Tuning' started by Creative_josh, May 28, 2012.
  1. Creative_josh
    Creative_josh Piaggio zip
    Ok so my friend tried to clean my air box and ripped the foam in half so I fitted a foam stage 6 filter but now the problem is it bogs down and doesn't pull away I'm guess this is to much air? And not anough fuel? Well it's a 17.5 delorto carb with a 64 main jet.... What should I do? And no fitting the air box back on is not a option :)
  2. Stig
    Stig Well-Known Member
    EXUP1000
    you've answered your own question...
    jet the bike to suit the filter
  3. Aaron hamling
    Aaron hamling New Member
    Piaggio zip 50
    or when you were cleaning your air box some crap got in the carb so i would clean the carb it happened to me to !
  4. Creative_josh
    What size jet would you say? It's a 64 now and bogging down to the point that it cuts out
  5. Aaron hamling
    Piaggio zip 50
    You should try cleaning the carb as well that could be the problem
  6. Creative_josh
    Tried a 85 main jet and the scooter is more powerful at pulling away but still at full revs it bogs down what could this be
  7. CA Zip tuning
    CA Zip tuning Member
    What filter do u have, and what pipe
  8. Bradley Nixon
    Piaggio NRG Power DT
    for standard peds, a 58 should be perfect, With exhaust and de-restriction 62, open air filter and pipe 92
  9. CA Zip tuning
    i run a 70 jet with a air box and yasuni z pipe
  10. Jonnymarrw00t
    Piaggio Zip 05 plate
    What should of been asked is it a Open air filter on a stage 6 insert filter ? if it's a insert no upjet should be needed. If it's a open filter more a 110.
  11. Creative_josh
    It's a open air filter the exhaust is just a piaggio sports and all of you are telling me dif sizes 85 jet works best but only up to 3/4 revs at 4/4 revs the bike bogs and goes to cut out but back to 3/4 revs runs like a dream it's confusing :)
  12. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    go full throttle till it cuts out and check your spark plug if its black your too rich and if its white colour its lean and if its brownyy colour its about right
  13. IceIceBaby!
    IceIceBaby! yz125/ TTR250/ sold gilera ice
    TTR250
    85's to small if its open air filter..
    Duggiedan likes this.
  14. Creative_josh
    So what size would you say go then? If 85 is to small like a 90? Before I had to change the air filter it ran fine on a 64 jet. It sounds like a huge jump 64 to 85?
  15. Bradley Nixon
    no, not for an open air filter, and you will be getting too much air for your mixture, put a 98 in, see what thats like, if it still bogs, put a 106
  16. Jonnymarrw00t
    Or just put the bloody airbox on ?
    IceIceBaby! likes this.
  17. gilly_runner
    gilly_runner Member
    Gilera runner
    If i was you i would buy a new foam for the airbox, your ped has not got a 70 kit so there is no point having a open airfilter as i will not run good and will just drink more fuel and make alot of noise, there will be little if any power difference with the filter (with the right jets) but you mpg will be way lower.... a pointless mod if all you need is the foam a malossi foam for the standard airbox is £6 with postage you will spend more money than that trying to find the right jet !
  18. CA Zip tuning
    Buy jets from 100 - 110. its trial an error should be around 105 mark
  19. Creative_josh
    It had a malossi filter in it with the 64 jet and I didn't want the open filter for power or sound I just like the look of them rather than a huge black box :)
  20. Jonnymarrw00t
    Well say good bye to your engine then
