how do you remove that standard handle bars from a piaggio zip? i have taken out the top bolt that goes throught the stem and tried hitting the handle bars up but they arent moving do i have to undo the bearing aswel? or it is just a case of shit loads of wd40 around the bottom of the stem and hitting them up with a hammer?
basically screw that handle bar bolt in a little bit an tap it a couple time with a rubber mallot then unscrew it and get some1 to hold the front wheel straight and just grip the handle bars and wiggle them side to side while pulling them up till they come off
