Ps the zip blew up today well pissed off that's a pm tuning kit down the drain There is the messed up piston
Hahaa, I wouldn't mind one, but I know two lads with them and they're constantly fixing them :/ a 172 rox would be my dreamm
Ohhh mine, put your 50 back in it that's why yours probably wasn't starting, lack of compression??? And this is my piston also a score on the otherside :/
yes i have had a few AC piaggio's and on rebuilds i used the OEW gasket set like this one http://www.pedparts.co.uk/product/1759/piaggio-air-cooled-50cc-gasket-set just because there not shown on a diagram docent mean they don't use them. Piaggio don't make a crank case gasket they use liquid gasket, so that would not be shown on a diagram but it still there? maybe they use liquid on the head? on an engine that as a compression in the cylinder of around 100psi there MUST is a seal of some sort as a little leek would make problem like running lean, not starting, cutting out when warm. again sir i think you are wrong
Haha not as bad as mine piston lol gunna get a new pistons or it as my barrel ant to bad so hopefully it runs again, and yer runner 172 always need work doing to them a right money trap What's was your 70 barrel like?
the 172 is the race spec kit, so it will need work. it like the MHR 70cc they need rebuilding ever 100 mile
ah no, he's completely correct the genuine Piaggio a/c didn't use a head gasket - I guess they relied on perfect machining to seal but I'd certainly use a smear of sealant to put one back together- all of the aftermarket 50cc a/c piaggio kits use a head gasket though andy
me too- the only time i've been wrong was that one time when i thought i'd made a mistake... but it turned out i hadn't
its getting fuel mate coz i have to remove the air box and put my hand over the carb and move it slowly to get it started :/
Choke not working. if you put your hand over the air inlet your making it work like a choke by letting less air and vus making it rich to help start. i would buy a manual choke pal
Well was thinking of buying a senconed hand one off eBay the same ad mine as cant find any with a manual choke, would it matter if I am running pre mix mate?
no, pre mix makes no difference as long as you adjusted your jetting or it will just lean. what carb are you using, you can get manual chokes for all carbs
It's a delorto 17.5 carb I am running a 80 main jet with a standard air box but a malossi form inside mate
flip up manual choke http://www.pedparts.co.uk/product/286/manual-choke-u-clip-type-conversion cable manual choke http://www.pedparts.co.uk/product/890/u-clip-choke-kit-manual-cable-adaptor dod you upjet the carb when you started to premix. the malossi insert need no upjet.
Was already up jetted as have a 70kit and race pipe onit mate Yer gunna order one of those chokes now cheers mate
