Piaggio Zip Acceleration problems
Discussion in 'The Workshop' started by CA Zip tuning, Mar 15, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    I got my pipe fitted and my ped de restricted and ever since as soon as i ride my bike for the first 40 metres or so im full throttling and it just makes a horrible coughing sound and stays at about 5 mph then slowly increases to about 10 i would say. It slowly builds up to sound normal but it dosent sound healthy attall. After this 40 metres it is fine and sounds normal again. Its just everytime i start it up and also if its been left for over 15 20 minutes it will do it aswell. I have a 58 jet in at the moment. Please help much appreciated thanks ;)
  2. Stig
    Stig Well-Known Member
    EXUP1000
    sound like a mixture issue IMHO. Have you adjusted the air srew?
  3. CA Zip tuning
    Nah mate what do i have to do
  4. jamieg01274
    jamieg01274 Member
    Have u upjetted your carb??? Since the de-restriction and new pipe???
    Duggiedan likes this.
  5. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    Sounds like could be overheating if u havnt upjetted since pipe and derestrictions i would recommend doing it just incase other wise u will be buying an expensive job
  6. CA Zip tuning
    my mate upjetted it but its only got a 58 jet in it went from a standard 52 to 58
  7. Duggiedan
    Piaggio Zip
    hmm seems a little too big when you open throttle does it try to cut out? and wat colour is your spark plug?
  8. CA Zip tuning
    it pauses and it dosent seem as if its running perfectly like if i slow down and then accelerate it will pause in between if u no what i mean its not flowing, also my throttle , even though i have taken my hand off the throttle the bike continues to run
  9. Duggiedan
    Piaggio Zip
    Hmm have you adjusted carb at all or messed with idle screw or air mixture?
  10. CA Zip tuning
    yh me and my mate looked at the carb today and fiddled about with screws down there
  11. Duggiedan
    Piaggio Zip
    Damm you didnt really need to fiddle with them now you have to mess around with them again to set carb up properly. When fitting a pipe and derestricting a ped all you need to do is upjet carb around 5-10%
  12. CA Zip tuning
    you know what i have warranty on the bike ima let the fuckers who i bought it off sort it out
  13. Duggiedan
    Piaggio Zip
    Yep That be best way it will save you alot of hassle :) need anymore help get back in touch
  14. CA Zip tuning
    ok cheers mate
  15. CA Zip tuning
    inbox me your facebook so we can chat on there
