Hello all, I rebuild my engine from 50cc to 70cc. New cylinder, new crankshaft and bearings. Removed the startermotor. The problem i face now is that there is no power at all. The engine runs fine at idle but the acceleration is pretty weak and it only goes to 40km/h. The color of sparkplug is gray. I couldnt ride that much because of fine tuning everything. I lowered the main jet from 100 to 90 because in beginning the engine was stuttering. That problem is now solved. I have already changed the sparkplug and the ignition coil. Piston etc. mounted correctly. I still think there is some problems with the ignition. Maybe the stator coil isnt 100%. I m not sure. What could be the problem? My setup: 70cc Athena racing (0.6mm squish) Athena racing exhaust Polini CP 21 carburator (new) Polini power fitler Malossi overrange pulley (purple torque spring) Malossi clutch (white springs) Malossi winbell Polini hi-speed variator (4.2 grams) Polini evo 3 half pulley NGK C4 race ignition coil
