I have a problem with my zip, it's got 70cc italkit bore kit 21mm dellorto race carb polini variator kit race cdi open airfilter 5.5gr polini rollers 88 main jet iv tried 89 jet and 92 but just bogs down after a lil bit of throttle my scooter start fine and idles perfect, do i need to up jet or down jet any ideas what the fucks up with it? many thanks
Have you checked the idle screw mate ? There is a guide in the guides section under carburettors if you need moro info.
it wont need upjetting with a carb that big on it, probably need down jetting mate.. or air/fuel mixture
Sorry but how many of you have ran a 21mm carb ? There is nothing wrong with them. Does it bog on full throttle or little ammount ? can it pull away have you tried a plug chop ?
i'm up to 110 main jet, warm days it sets of fine but cuts out after 3 minutes,on colder days it starts up but bog down after half throttle, adrenalinpedstops think i have an air leak, so iv order a new head gasket set. see what happens when i fit them.
it was fine right up till i went out on a nice hot day up on moors having a nice ride then it cut out started back up after half hour, i eventually got it home after cutting out every 5 mins, ever since then i just can't get it to go perfect, i must of burnt my gaskets out.
