Piaggio zip 50 2t won't start
Discussion in 'The Workshop' started by romatom, Nov 25, 2012.
  1. romatom
    romatom New Member
    Piaggio zip 50 2t
    2002 piaggio had it running turns it off went out about 3 hours later and it didn't start I've cleaned all the carb but it still won't start
  2. astro77
    astro77 Active Member
    have you checked for a spark also is the plug wet after you've tried to start it?.
  3. romatom
    romatom New Member
    Piaggio zip 50 2t
    Yeah done the obvious but still not starting?
  4. astro77
    take the plug out and tip a tiny bit of petrol in then refit plug and try it and see what it does
  5. PX Jamie
    PX Jamie New Member
    Vespa
    got fuel flow?
  6. romatom
    romatom New Member
    Piaggio zip 50 2t
    Gunna try putting petrol down first and yeah got fuel flow
  7. Stig
    Stig Well-Known Member
    EXUP1000
    check the plug, clean it up and gap it, then rest it against the head to check you've got a good spark whilst turning it over
    Try some easy start down the inlet to see if it fires
  8. scubabiker
    check youve got oil, maybe your oil pump belt has snapped
