Piaggio zip 4t
Discussion in 'The Workshop' started by Adam6576, May 14, 2020.
Tags:
  1. Adam6576
    Adam6576 New Member
    I have a piaggio zip 50 07 4t completely Standard 1200miles on the clock was wondering what should I do to make it faster I’m not that familiar with 4stroke engines
  2. scubabiker
    Take the restriction out. Probably a spacer on the vario. Marsh will know. Or Mark?
  3. Mark Emerson Trentham
    U-tube video - cut the wire in your CDI;).......
    stick with standard airbox - if not be prepared to properly experiment with jetting as it'll bog the shit outta your motor.
    ********Research' & follow instructions implicitly or you'll f**k up your CDI;)********
    There are 4t tuning exhausts available & 80cc kits.:).
  4. Mark Emerson Trentham
    Afterthought.... .
    If you decide to revise/update or renovate your brakes - there are 2 types of front caliper generally for this model,make sure you get the right one for your model.;).:):).
