piaggio zip 04 2t revs dying above half throttle
Discussion in 'The Workshop' started by philzee, May 12, 2013.
  1. philzee
    philzee New Member
    Hi,
    I have a piaggio zip 50cc 2004 2 stroke. While it starts no problem, it suffers from power loss while revving over half throttle, the revs die until it finally cuts out unless you close the throttle.
    Here are things I've checked so far:
    Tank breather hose isn't blocked
    vacuum fuel pump is working
    Carb has been cleaned out with carb cleaner including jets and float chamber
    all fuel hoses are clear of blockages
    fresh fuel from Shell added
    It even does it when up on the stand so I don't think its a roller or belt issue. I can't think what else it could be?. It was running fine with loads of power but now its a nightmare!
    Any help appreciated ;)
  2. MiNoR cOnFuSiOn
    have you put a filter/pipe/changed anything recently? could be a few things... wihtout knowing more i cant help, flat ass rollers id say from what youve said
  3. philzee
    philzee New Member
    Thats the puzzling bit. I haven't done a thing to it, it was running fine and now its not. When you say flat ass rollers, what does that mean? should i replace the rollers?
    I was going to put it into a Piaggio dealer to get it checked out by someone who knows them inside out, but he wanted £48 per hour :eek:
  4. Xx-Holland-Runner-xX
    Xx-Holland-Runner-xX New Member
    maybe your carb setup, the size of the jet maybe flooding it, or you could lower the rev's pin in the carb
  5. philzee
    philzee New Member
    Just a quick update to close this thread.
    Found out what the problem was after much head scratching and stripping the bike down.
    There was an air leak on the inlet manifold side which we tracked down to the reed valve not closing properly. Bought a new one and also replaced the inlet manifold as the rubber was a bit slack. total of £27 quid on Ebay. Scoot is back running sweet as a nut now :cool:
