Piaggio Vespa ET2 newbie question.
Discussion in 'Newbie Scooter Tuning' started by Adidas123, Nov 16, 2011.
  1. Adidas123
    Adidas123 New Member
    Hello i have got a question. I will going to buy a Piaggio Vespa ET2 50cc(2000) it is stock.So i want to ask what the first things i can put on it to increase the top speed and acceleration.Thanks !! :)
  2. brettfield999
    brettfield999 Member
    Typhoon 172
    http://www.scootershack.co.uk/budget50guide.html
    The only issue you will find is finding an exhaust that will fit as there are nigh in none available. Apart from that it is the standard AC piaggio engine you will find in a typhoon, stalker, nrg and zip
  3. tErr0
    You can always get one modded to clear the panels however. I have done this on my ET2.
  4. Adidas123
    Hello thanks for reply... I`am thinking of putting this setup on my ET2
    Stage6 Racing 70cc kit. £155.
    Yasuni City 16 exhaust. £205.
    Stage6 Jet Box. £13.
    Polini Hi-Speed Variator kit. £74.
    3 Sets of Malossi rollers. £21.
    Polini Clutch Spring box. £10.
    Stage6 Primary Gear-up. £56.
    Maybe there is any other little bit cheaper exhausts which would be perfect for this setup??
  5. brettfield999
    Typhoon 172
    My choice and add a 21mm carb for throttle response:
    Malossi Sport 70cc kit. £126.
    LeoVince TT exhaust. £76.
    Can of VHT (Very High Temperature) spray paint. £10.
  6. Adidas123
    Im think better is stage6 kit coz is more powerfull and faster.but im just intrasting which other cheaper exhaust i can put on it?
