Discussion in 'The Workshop' started by vespaphil23, Feb 10, 2009.
  1. vespaphil23
    vespaphil23 New Member
    Vespa
    hello
    I have a piaggio Typhoon 50 and i want to put a 125 engine into the frame
    Are there any other engines that fit in apart from the typh engine
    i heard and sr engine fits in as standard? and it has to be 2 stroke and air cooled
    whats the best way to make it go super quick
    cheers
  2. MiNoR cOnFuSiOn
    buy
    a
    fucking
    125
    done
    cheaper than parts
    you dont know what your doing
  3. vespaphil23
    Vespa
    i would like it to be a 180 so i would be buying the parts?
    i have a 50 frame
    the fucking 125 as described are very pricey to start off with?
    your looking at £500 notes for a 125 then there is the price to make it a 180 ??
  4. kyle1b1
    :w00t: :w00t: :w00t: :w00t: :w00t: :w00t: :w00t:
  5. MiNoR cOnFuSiOn
    so what,m you gonna go STEAL a 180 for the parts then are you? as PARTS cost MORE than 125's do (your prittymuch buying a bike in bits, an there are NO good second hand std engines about so any second hand one WILL need a rebuild)
    ask ANYONE who has done a conversion how much it ended up costing(ye i mean WITH an mot, so 99% of these idiots dont count)
  6. typh70
    typh70 New Member
    looool at minor
    i understand where your coming from mate you want a fast bike n all that
    i done a conversion and i know a fair bit about peds ( not much but a bit )
    and it turned horribly wrong
    buy a 125 or dont do it
    really not worth it
  7. vespaphil23
    Vespa
    Ok forget the 180 cc for now if i got a aprilia 125 sr engine would it fit in to typh frame
    i know what your both saying
  8. INO
    INO Member
    you can buy my piaggio typhoon 125 ?
  9. INO
    INO Member
  10. vespaphil23
    Vespa
    i am ok thank you i already have 3 scoots
    but thanks anyway
  11. nibbles
    nibbles Active Member
    1200 with tax and test
  12. nibbles
    i disagree to be honest .its illegal unless all swapped over .but whats not illegal any none emarked pipe for a start .i think i could get 125 stadard on road tax n tested in a zip frame for 500 .ironicly the price of the bike lol .in some cases in fact a lot of cases it aint worth it BUT IN SOME ITS A FUKIN GREAT IDEA in my opinion that is
  13. alperin
    alperin Active Member
    aerox 180cc
    hes right thought the same thing was like yea all i need is the loom and engine but nah lol everyday something new to buy comes in i should of just bought a 125 instead of making one and plus its not easy to re register as 125 very long hastle mate.
  14. seanwhite06
    seanwhite06 New Member
    runner 172, zx6r
    you will need
    engine,loom,exhaust,carb, correct back wheel and caliper/disc for the engine,125 clocks and switchgear ( if your planning on registering it legally as a 125 ie needs full beam etc.) and 125 rad if doing lc! ooo and a side stand!! then add tax and mot and its close to 500 quid.
    just sell the 50 and use the money to buy a 125 in the first place. much cheaper and much less hassle in the long run!
    ive been there done the conversion, (runner 50 to 180)
    the only way ive found you can do it cheaply is buy buying a written off bike, (frame/ panels/ forks etc fuked) but with the engine and everyting still attached! and even then it is alot of hassle. and you need a good brain about ya as its really aint as simple as its looks half the time!
    espec getting it legaly registered! ;)
  15. alperin
    aerox 180cc
    yup what he said.
  16. MiNoR cOnFuSiOn
    sr engine is the same as a typh,... BUT its solid mounts, they last 2 mins in a normal frame/mount.. sell it,
    as for legality, you DO realise you ether need to take it for a dvla inspection, have a shop do the wor2k2 or have an sva test to turn a MOPED into a MOTORCYCLE. nobody see2m2s to facter2 this into the cost
    there 2is ONE reason to do a conversion, when you want a bike you CANT buy as a 125 as a 125, have ALL the parts at your disposal, the basic knowhow to do the job and have a clue about legality.
    the other hasels are once its built.. the brakes are the same on the 50/125 as are the foirks in some cases (typhoons) but the petrol tank is NOT the same (125 has 2 tanks) i get 20 odd miles out of my 50 tank with the 70 inn (big carb, its a drinker) on conversions your lucky to get that.. let alone sommin quick, as for the engine mount';s there CONSTANTLY wearing out..
    honestly.. sell your bike and BUY a typh 125..
  17. TyphModification
    TyphModification New Member
    Typhoon Gilera 70
    Ive just finished my conversion, I picked up a cheap gilera runner engine off gumtree with all tuning parts on it stripped it down and rebuilt it and it was fine i just bolted it in my frame but i had a little proble with the wireing etc but thats fine now all i need is a back brake system which dys is sorting me out with and thats it :D
    My engine cost £120 and came with malossi 70 bore which was brand new only done 100 miles, pm 360 pipe, polini clutch etc etc so that was a good deal. and all i need to do now is get the brakes and shit off dys.
    So all im gonna spend on my conversion is gonna be £130-£145 the most.
    My dad used to work in stoppies in wallington surrey, HE has helped me out quite alot with this project and said it will pass an mot without no problems.
    Which isnt bad atall ayy minor.
  18. nibbles
    yhyh 70 is obv easier m8 no1s saying that m8 as no hassle swappin the class of the ect ect but i have a nrg 172 cozzzzz it came cheap .along with all the work needed .as i said there are many cases were theres no need and some were its silly not to imo .
  19. TyphModification
    Typhoon Gilera 70
    If it runs perfect and is ready to ride away i will have it and how much u looking for ???
