piaggio typhoon engine problems
Discussion in 'The Workshop' started by philip, Mar 7, 2015.
  1. philip
    philip New Member
    Hello every iv bought a 2007 piaggio typhhon the other day and it has theses parts on it im not with bikr at the min so iv got thw pics off internet as i dont no were the pipe go could someone help me set it up please with a walk through
  2. philip
    philip New Member
  3. Nathanael
    Nathanael Active Member
    Are you asking which pipes go where on the carb?
  4. philip
    philip New Member
    Hello yes i am
  5. Nathanael
    The skinny oil pipe goes on the small brass barb on the side of the carb.
    fuel pipe into the vertical brass one next to carb mouth.
    If you have a vacuum hose as well it will be the top angled brass one at other end of carb.
    The 2 silver ones pointing down are vents and dont need connected to anything.
    You may or may not have 2 brass ones left over, dont worry about them if you do, they are for coolant on water cooled engines.
