piaggio typhoon 125 engine
Discussion in 'For Sale' started by 2stroke-power, Sep 19, 2010.
  1. 2stroke-power
    2stroke-power Active Member
    on 1-wheel
    piaagio typhoon 125 2002 rolling nut model engine comes with what you see .
    all it needs to run is .rear hub bearing £10 and seal £7,a outerpully,and the small black part of the statorand the air cover..also has brand new rear shock bush srt and both engine buses srt.
    £150
    malossi exhuast fro gilera 125 172 180 and italjet draGSTAR 125 172 180 basilcy brand new sprayed vht gloss black .bargin best pipe on the market
    paigio typhoon panels sprayed gloss black pro spray job .front ,two sides ,under belly ,rear mudguard and spark plug panel are all gloss black the two other inners are standed .there are a few minopr scrathes and chips from stones off te road but nothing bad atall grab a bargin and make your bike look fresh.
    £130
    malossi belt and tortion control brand new £20 for both
    pick up from north london
