Malossi MHR Replica - 80 Well i can provide video of it running, come with a new base gasket, and my old gaskets, can send the old circlips if you want, but use at your own risk. Always ran on Castrol TTS. done around 3000 miles... Static compression of above 140psi Still plenty of life in this baby, and ive got video so no bullshitting here. Yasuni City 16 - 100 Freshly wirebrushed and rust removed and sprayed with Black VHT @ 600c. Does come with damage to the endcan, at the start and the tail pipe, doesnt effect performance.. Cases Flowed and Matched to the rep - 30 Obv zip cases. so only used for the zip ac/ or lc. Motoforce Evo Crankshaft - 50 would prefer to sell in the cases so yeah. done around 3000 miles havent had a problem. Malossi Variator - 35 We all know what one looks like right lol ? comes with the black spacer and white contra Stage6 Front Pulley - 15 posted Used obviously, more than half the weight of standard. Stage6 Belt - 5 Used, done about 3000 miles, can only be used in a zip. Malossi Overrange Rear Pulleys - 90 Excellent pulleys NEEDED if your going high end. two adjustable rates so make the powerband wider for easier adjustment, real piece of kit Stage6 Torque Control Clutch - 50 come in original box, white, orange and red springs. the clutch, jeez can you get better ? Malossi Wing Clutch Bell - 25 Keep the clutch cooler with the wingss. malossi? the best Malossi Gear Up - 50 Comes pressed already, in the gearbox case, with fresh bearing and seal, again this is never been fitted to my bike so the bearing and seal have been replaced by me so you just need to take old out and place new one. 5 min job! Dellorto racing replica 21mm Carb - 50 YSN make. 5mm main jets. black. easy access to the main jet for them crucial jet chanes. Malossi TC Ignition Unit - 60 removes limited and better at high rev's as handle revs better and doesnt retard ignition as much as standard unit Malossi Fly clutch with malossi springs. - 20 posted Better than standard clutch well easier to change the springs on.
