hello, ever since ive had my nrg the fuel guage hasnt worked it just flashes on empty constantly would anybody know how to fix this? may it need a new sender or is it an electrical fault as it has digital clocks??? please help would be much appreciated. the other thing is i put a set of malossi front brake pads in it about 3 weeks ago and there down to the bare metal already? i dont ride it perticurlaly hard are they just shit pads or might of i glazed them over? and it is due a rear tyre any recommendations on what tyre to put on? cheers, AHJ
stuck float? and the malossi pads are the best pads for peds tbh you must be doing something wrong no brake pad lasts 3 weeks
i sprayed anti squeal spray on the back of them and put them in?? rebled the brake and 3 weeks later fucked!!
how many wires go to the fuel sender in the tank. If theres 2 join them together and see if the guage moves to full. If theres one, attach it to earth and then try the guage again. If its full the guage is working and its the sender end that needs sorting
one of the pads were down to bare metal the other one was okay due to a seized slider cleaned all the caliper up and greased it all and it seems to be loads better. and the other thing when its hot after a long ride it feels sluggish to pull away could this be a worn clutch or someone told me it could be flat spots on the rollers? and when just going along at low revs when you let off it makes this sort of chinking sound from the tranny casing? any ideas on what this could be?? would be a massive help cheers guys
