Hey guys, i've just bought myself a second hand NRG Power. Just spent 150 quid on fixing it too, but its still underpowered. i have a few things i want to do to improve the performance and power so tell me if im doing anyhtin bad here Current NRG: 100% Stock De-restricted. Upcoming NRG:- Stage6 Streetrace 70cc - Cast Iron - Piaggio 2t LC engines. - £103.95 - CPH High mass crankshaft - 50 - 70cc Piaggio engines. - £41.50 NEED NEW CRANK!!! i know its not necesary! - Polini Variator Roller Weights 4.2g - £8.17 - Polini Hi-Speed Variator Kit - Piaggio based engines. - £41.83 - YSN 17.5mm Carburettor - Piaggio models - £45.98 - YASUNI R : Aluminium Silencer EXAUST - Piaggio engines - £139.82
Well you will need new main bearings when getting a new crank. You also don't need a carb as your's is 17.5mm as standard and you will need more than one set of rollers to try and find the ones right for your setup and you need a box of jets to set the carb up. You will also need some clutch springs and some VHT paint to paint the exhaust to stop it rusting.
Thanks very much terr0. Iv'e just changed the rollers and clutch springs and intalled a viper exhaust insted of a yasuni. goes very well now. i think ill give the 70cc kit a skip for now.
