Oil light will come on when key has been turned for a couple seconds and also come on when I try electric start but that doesn’t work don’t know to much about nrg’s so any help will do.
So you saying, it doesn't light up when oil is low or empty? The reasoning behind it just flashing for a second when the scooter is started up, is just for you to know the bulb isn't broken.
Ahh okay was just a bit concerned as didn’t know if it was telling me the oil was low or something on them terms also what would u suggest me doing about the electric start as the motor doesn’t even seem to be spinning could I just replace the starter motor or could it be something else thanks,
I'd start with removing the starter motor and just try it first. Just connect it to the battery. To see if thats the one is broken before buying a new one. If it works. Something else is at fault
