piaggio nrg mc3 lc jet size
Discussion in 'The Workshop' started by topgear1, Oct 29, 2010.
  1. topgear1
    topgear1 New Member
    hi could any tell what the standard main jet size for a piaggio nrg mc3 lc with the dellorto 17.5 mm carb is,also i have a leo vince tt pipe unfitted would i have to upjet the carb for this,if so what size do u reckon thanks
  2. topgear1
    topgear1 New Member
    ive opened up the carb and its got a 95 jet in,should it have a 56 and around a 75 with the exhaust? thanks
  3. samaroo44
    samaroo44 Member
    zip 125 conv thing
    you got open filter or air box?
  4. topgear1
    topgear1 New Member
    just the standard airbox mate
  5. topgear1
    topgear1 New Member
    also i got the leo vince tt pipe second hand with no rollers etc would i need to change the rollers the standard weight is 7.5g any ideas thanks
  6. brainjuicer
    brainjuicer New Member
    im with 70 mainjet, giannelli extra, blue clutch springs, 4.7g rollers and its running great ;) the roller size must be around 4.5-5.5 try and new clutch and torque springs ;)
  7. topgear1
    topgear1 New Member
    ive changed the jet from a 95 to a 62 its going alot better,ive got some 5.5g rollers on the way,im going to change the belt at the same time what do u suggest a standard belt or kevlar thanks
  8. pedmaniac
    pedmaniac New Member
    hi i have a piaggio nrg mc3 aswell with the leo vince tt exhaust and i would like to know what jet size i need for the carb and my ped is really bogging down alot. thankyou
  9. Jonnymarrw00t
    Piaggio Zip 05 plate
    The engines are almost the same as a zip engine (Just the size) My zip is using a 65 with a tt pipe. TT rollers are 6 grams. I'm using 5 grams :)You will need to change your clutch springs too. The TT comes with light blue springs, Not sure what they translate as on other springs though. Hope it helps.
