Piaggio nrg blowing fuses
Discussion in 'The Workshop' started by Ryan Peacock, Jan 2, 2013.
  1. Ryan Peacock
    Ryan Peacock New Member
    01 Piaggio NRG
    Hey up chaps, my bike has now decided it wants to blow a fuse every time I turn the key in the ignition.
    It started fine this morning but lost indicators, fuel gauge and rev counter on the way to work... Checked the fuse and it had blown so went to replace but it blew as soon as the key turned into the on position.
    Could it be the regulator?
  2. Stig
    Stig Well-Known Member
    EXUP1000
    check the main loom and battery live where it passes through the frame rail, it could have worn through and earthed causing the fuse to blow
    Ryan Peacock likes this.
  3. Ryan Peacock
    01 Piaggio NRG
    Cool I'll check this thanks Stig
  4. TalkToShank
    TalkToShank Life is short... so Grip it and Rip it!
    if you just wanted to bodge it you could always put some copper wire round your fuse... it wont blow up then :L
  5. Stig
    EXUP1000
    A BIG FUCKIN NO!
    it'll melt the loom in hidden places and can cause a fire
    TalkToShank likes this.
  6. Ryan Peacock
    01 Piaggio NRG
    I think I'll just go down the standard route and look and repair.... No need for cowboy copper wire
  7. TalkToShank
    ohhh... :/
  8. Ryan Peacock
    01 Piaggio NRG
    It would appear my starter relay had some how taken on water, new one fitted all is well... (Fingers crossed)
  9. Ryan Peacock
    01 Piaggio NRG
    Well fingers crossed didn't work, I've stuck a universal relay on for the time being until my piaggio relay comes and it didn't work.....
    The wiring is all fine and intact, battery is fully charged, regulator was fitted brand new today, all electrical connectors are fine.
    What else could it be?
  10. Stig
    EXUP1000
    it COULD be a blown bulb that shorting the circuit...seen it a few times
  11. Ryan Peacock
    01 Piaggio NRG
    There all fine
