Piaggio NRG 57 plate setup and jetting tuning
Discussion in 'Scooter Tuning' started by mhr-rox, Aug 18, 2010.
  1. mhr-rox
    mhr-rox Member
    i have a 57 plate nrg has a malosi sport 70 kit,malossi delta clutch with red springs and malosi contra spring fittted ,zx pipe, and a 19mm carb with 95 jet and airbox, un sure if it has the multi variator as cant get nut of to se and 5.5 gram rolers
    basicaly when i ride it it sems to get to 50 and sttrugle or sort of mis fire id say any help on this wil be changing zx for a yasuni c16
  2. capri dave
    capri dave Active Member
    Re: nrg 57 plate help
    could be jetted too rich....95 jet is a little on the large side for an air box :glare:
    what airbox are you using, the later air boxes are air restricted, and need modding to flow well...the earlier triangle shaped air boxes are much better :)
    failing that it could be an electrical/ignition fault, a worn or fouled spark plug maybe..
  3. mhr-rox
    mhr-rox Member
    using the airbox it came with jeting sems to make litle diference as tried it with 92 to 95 ges beter with the 95 and loking to change pipe for a yasuni c16
