piaggio nrg 50cc lights , bore kit
Discussion in 'Scooter Tuning' started by nrgjordon, Aug 26, 2010.
  1. nrgjordon
    nrgjordon New Member
    hi there
    my light on my nrg mc3 are very dull how cam i make then bright ?
    and seen a donotlink-pedstop bore kit are thay much good ? and what speed would i be hitting?
    thx
  2. DASH.
    DASH. New Member
    Zip 70.
    If theres no fault with the lights you just want brighter ones then buy brighter bulbs?
    and the link doesnt work but i would recoment a malossi or polini 70s kit, what is the setup of your bike or the setup your going to run with the 70s kit?
  3. nrgjordon
    yer i will get some new ones ! as i dont have hit or low beam ligths grr
    im going to be geting
    17.5 or 19 mm carb (jet kit alwell, need)
    malossi bore kit (need)
    doppler s3r exhust ( new )
    5.0g rollers (got but may got heaver)
    and going to get a pm tuning clutch (need)
    thx
  4. DASH.
    DASH. New Member
    Zip 70.
    Id get a 21mm carb instead of the 19 personaly but the kit your looking at is good enough, you will deffently need heavier rollers than 5g.
  5. DASH.
    DASH. New Member
    Zip 70.
    i suggest a mix of 7.2 and 5 that mix has always worked well for me.
  6. nrgjordon
    yer i will get some new rollers then
    and what carb will bang striaght on ! (piaggio nrg mc3 2002)
    thx
  7. DASH.
    DASH. New Member
    Zip 70.
    Any 21mm carb will fit aslong as its the same as ur bike liquid/air cooled.
  8. nrgjordon
    yer its air cooled iv seen some carbs but dont look the same as what i have soo must be liquid
    what set up is your bike ?
    and what speed you geting out of it ?
    thx
  9. DASH.
    DASH. New Member
    Zip 70.
    21mm carbs look different to standard ones, as long as it sais on the decription of the product that it fits your bike you will be fine.
    my set up is a polini 70 malossi 21mm carb and a pm, the clocks on zips as you probibly know only go up to 50 but my mate on a 125 runner clocked me at 65 (ped speedo) comfortably.
