Hi all, I have picked up the above scooter. Just wondering if anyone has a workshop manual or expert knowledge that could help me with a couple of bits? 1. front light & tail light not working - could this be a fuse/relay, if so where is it located. 2. is there supposed to be a washer on the rear wheel shaft between the clutch & case? 3. do all the panels need to come off to get access to the carb? Many thanks in advance! Andy
Yeah or you might be able to find an online one at carlsalter.com l think it's called if my memory serves me correctly.
hi MARSH - thanks for response. was kinda hoping to save money by asking for advice on here first. hi milo2025 - thanks for link, can't see liberty on there but will check if it copies any vespa models
I haven't worked on a Liberty for years, could be be fuse or switch, yes there's usualy a spacer on clutch and yes a lot of panels off to get to anything !!
hi guys just a quick update. turns out the liberty has fuses for the lighting - who'd have known! anyway i have replaced the fuse and the rear light now comes on. seems the front double filament bulb has blown as well so got a new one or order. cheers for all your help
How did you get on with the carb. Normally there is a "carb access panel" under the seat on Piaggio scoots
