piaggio lc 70 running problems,
Discussion in 'Scooter Tuning' started by derekjohn, Jun 8, 2012.
zip, nrg, typh?
  1. zip
    50.0%
  2. nrg
    50.0%
  3. typh
    0 vote(s)
    0.0%
  1. derekjohn
    derekjohn anyone got a 125/172/182 engine for sale?
    NRG power
    my bikes got a aluminium doppler 70cc kit standard crankshaft gears and variator, pm tuning reeds 21mm carb and race filter, its recently not enjoyed starting atall and has no power and then will stop when it gets to warm, it sounds like a sparking problem when im driving and it apears to be like a seizing problem but i couldnt see any seizing marks on the bore, any thoughts?
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Crank bearings more than likely. Or your ring is worn out.
  3. derekjohn
    NRG power
    theres no marks on the piston that suggest ring failure... not to mention you cant get rings for the doppler 70cc bore how could i find out without stripping the case?
  4. Jonnymarrw00t
    Compression ? really what I do with my ali kit is, take a measurment of the ring before I run it, then when I want to check it to see if it's warn down....
  5. derekjohn
    NRG power
    No the rings are fine lol if theyd worn therrd be carbon on the piston i meant bearings
