Will any piaggio 50cc engine fit in any piaggio 50 frame? Do the 125 engines fit in the 50 frame? All 125 engines in all 125 frames? Liquid and aircooled fit in opposite frames? Thanks
all 125's fit in all the 2 stroke frames.. the 4 strokes are different.. all 50 mounts are the same altho the zip is a shorter engine and the dna is longer.. so the shock mount is closer/further back. changing from 50 to 125 takes grinding/preferably welding to reinforce the mount.. 4 stroke and 2 stroke runners basicly need a different engine mount, you just ignor/use the second shock mount. 4t in a 2t wont work as theres usually no shock mount for the other side, oh and its GAY buy the bike that has the engine you want.
