Piaggio engine compression?
Discussion in 'General Scooter Discussion' started by Markie76, Oct 9, 2013.
  1. Markie76
    Markie76 Member
    Hi,
    Does anybody know what the factory spec cylinder compression (PSI) for the following engine should be?
    1998 Piaggio Liberty 125cc 4 stroke pre-leader engine
    Thanks,
    Mark
  2. richy1985
    richy1985 Member
    Try and google mate or haynes manual
  3. Markie76
    Markie76 Member
    Thanks for the reply.
    You might be surprised to learn I have tried google and found nothing - well, I'm here in an attempt to avoid spending £20 on a haynes manual just to find out what my engine compression should be :)
  4. richy1985
    richy1985 Member
    got a piaggio my self so I got a Haynes manual here. it says liberty 125 four stroke engine compression ratio 10.6 to 1
  5. Markie76
    Markie76 Member
    Cool, thanks!
    So 10.6 x 14.7 = 155.82.
    My engine is showing 155-160 on the compression tester after 5 seconds of cranking - so my engine compression is ok :) If my calculation is correct....
    I also did the timed time test;
    6:30 - I got 167 PSI
    7:30 - The tester was showing 160 PSI
    So it dropped by 7 PSI over an hour - is that good/bad?
  6. richy1985
    richy1985 Member
    yh yours must be ok mate
