Phbn/phva carb setting?
Discussion in 'The Workshop' started by Dae2830, Nov 20, 2017.
  1. Dae2830
    Dae2830 Member
    Hi
    Is the Dellortos phbn/phva float bowl able to set? Or is it a fixed setting on these models?
    Cant find any info on this model so assuming there is none to tell.
    Symptoms are a wet plug and bogging at higher speeds, just dies slowly.
    Currently also going to get another exhaust as the one i have looks heavily gunked. When i took it off a thick sludgey black goo came out of the end connected to engine...
    Thanks in advance
  2. scubabiker
    Too big main jet?
  3. Dae2830
    Dae2830 Member
    That did cross my mind as well after everything i have read. No idea what it should be thou.
