Ok finaly i got some free time so i've decided to post up a few more stuff, i'm getting the Port timings guide ready too but i need to revise it since i don't want to hurt anybody's engines with typos off my part. in the mean time i would like to contribute to those who happen to have a PGO BigMAX 50 scooter, i know this scooter is a minarelli legend model engine, but when it comes to finding parts for it any one will be stumped. Not only does this bike have an ackward custom cranckshaft, it also has mixed Honda/Yamaha parts inside. I own this bike and it's my base machine for all of my tuning needs. Below i have listed all the parts that will fit the bike nicely for those of you wanting to know before you go buying stuff you'll have no use for later on . The crankshaft -------------- the stock is a beefy full circle one stronger than most other bikes and can survive circa 12K~12.7K rpms (personaly tested and approved), if you don't have a secondary replacement at hand and would like to improve the failsafeness of this crank, use these bearrings with it. if you would like to switch to a full mass version, BGM is the only make who makes the PGO race crankshafts Code: BGM crankshaft model: BGM034113 complete Engine Casing kit -------------------------- (replaces yours completely and adds a rear disc too , if you do this you're on your way to EVO class engine specs ) Code: RRP Minareli : RRP007 Subframe modification --------------------- Code: Keisler subframe kit *10cm wheelbase extention : KS100019 cylinder kits: -------------- Code: Hebo Manston replica 68cc AC Alu : HR4000161N Malossi MHR Replica 68cc AC Alu : M318437 Malossi Sport 68cc AC : M317083 Polini Evo 68cc AC Alu : P166009810 Polini corsa 68cc AC alu : P1660076R Polini Sport 68cc AC steel : P1660076 Stud kits (for those who uses 80mm and other non standard conrods) ------------------------------------------------------------------ Code: Hebo stud Kit 85mm : HR5200956 Exhaust kits: ------------- Code: Polini 50cc Evo AC/LC : P2000246 polini 70cc AC : P2000240 Polini 70cc Evo LC : P2000241 Manifold pipe / Admission pipe (all the same) --------------------------------------------- Code: Hebo Manston 29mm : HR7000802 Malossi 12-21mm : M028481 Malossi 15-25mm : M028857 Polini 15-25mm : P2150401 Manifold spacers ---------------- Code: Keisler AC/LC std : KS100008 Keisler AC/LC 28mm : KS100008A Reedblock / Bigblock -------------------- Code: Malossi std : M277731 Malossi MHR : M2711817 Polini sport/Evo : P2130046 Carburetors ----------- Code: Arreche 17,5mm : AE51753 Dell'Orto PHVA 17,5mm : C12233 Dell'Orto PHBG (BS) 19mm : P2010156 <--polini distribution Dell'Orto PHBG 19mm : D02695 <---Black Edition hassle free tuning fun :) Dell'Orto PHBG 28mm : 40020000 <-huuge performance or huuge waste of money depending on your setup Malossi 19mm : M1611042 Malossi 21mm : M1611038 Polini 19-21mm : P1770064 Polini 25mm Dellorto base : P20110151 Variators --------- Code: Malossi Multivar : M518852 Polini speedControl : P241490 Polini speedcontrol kit : P243020 polini Racing overrange : P241490 Drive Belts ---------- Code: Hebo Speed Belt : HR5060103 Malossi X Kevlar : M6112729 Malossi X special : M6112730 <--tough as steel garanteed to rip your torque drive shield in half if ever your bearrings break on you. Polini Evo Kevlar : P2480401 Polini std : P2480032 Clutch ------ Code: Hebo sport clutch : HR5000104 Hebo race clutch : HR5000104R Malossi flycluth : M529450 Malossi Deltaclutch : M529451 Polini Speed clutch : P249004 Polini speed clutch 2G : P249008 Speed drives ------------ Code: Malossi torque Drive : M619223 Malossi torque Drive : M618312 Polini speed Drive : P244541 Transmission (can be mix matched with malossi + polini parts) ------------ Code: Malossi primary 13/44cogwheel : M678375 Polini Secondary 14/41cogwheel : P2021321 polini Secondary 15/42cogwheel : P2021346 phew looong list but hopefuly i didn't leave any out. Stage6 parts i don't have any at hand or in the area yet so i can't confirm their compatibility but stay tuned for updates as i finish the complete parts list
