Right, I'm back. The main jet I ordered for the specific bike arrived and was too small so that's a dead end. Spoke to my uncles mate who used to fix bikes, he said if it doesn't start on the electric start then it must be an ignition problem, what's causing it to start on the kick but not the ignition. Made me think back....this thing... Remember when I first checked the bike over, the live wire (red) was corroded and green powdery rust. The battery is charging AGAIN so luckily my sym DD50 had the same relay so I'm going to try that tomorrow with a fully charged battery, you never know. I might if blown the one that was on the bike some how. I'll give it a test on the multi meter, does anyone know how? Thanks.
its a relay...take a multi meter and put it to resistance..put one of the probes on one of the terminals and touch each of the other terminals until you get a reading..if you dont get a reading from that ,move the probe to the next terminal and retest in the same way.eventualy you will get to the point were two terminals will give a resistance...these two terminals are the coil connections .the other two are the switch..this is a normaly open relay(n.o)the switch will operate and give a short circuit reading if you put a voltage across the coil contacts and a mutimeter across the two remaining switched contacts.simples
Update time. Been working on the scooter tonight. After fiddling with the idle screw, It's idling ok, still dies out after a while but nowhere near as quick as before. Especially when it's cold. Went up the road and back like a dream, thing is, it idles but when you give a bit of throttle, it'll rev really high and just stay at that, won't drop back down. The throttle slide isn't getting stuck because I checked and saw it moving up and went back down after the revs stayed high. This is the only problem now I think. EDIT: forgot to say, I've gone back to the oil tank and petrol in their separate tanks. No more premix, oil pump does seem to be working
Check the position of the air mix screw; it could be too many turns out. Should be around 1 1/2 to 2 turns out.
There's 2 screws, one with a Philips head and one with a D shape which I've filed a notch onto so I can use a flathead to unscrew it. so it goes like this: Phillips head is unscrewed 2 turns. Flathead is screwed in all the way, nearly snug.
I'm an idiot, I'm getting mixture screw and idle screw mixed up. The mix screw is all the way in. Doh!!
Got it running ok, still not 100%, I turned the mixture screw out 2 turns and that's it. Could hear it was dropping after the throttle was closed, not normal idle sounding yet, had a run up and down the road to test, seemed lacking in power a bit, I'll do more at the weekend.
Sounds like your more forward than backwards with it..if you ain't done a compression test yet.,might be an idea now you've got this far.if your compression is good then that can be ruled out and the carb can be concentrated on..you probably will need a bit more jet tweaking but if your compression is low it could deceive you into thinking its carb issues.lack of power could be one or the other or a bit of both.well done for persevering with it...
Okey doke...nice to hear your happily chugging along..stevep will get ya through that dinky problem..well done getting this far..have fun riding it and feather the throttle at a standstill till its cured.,it will get cured.,
just turn the idle screw in til it wont stall, if the revs sit up after that then start turning the air mix screw out an 8th at a time til it revs and drops down clean
Ok update time again. I've been quiet for a while but I've still been tinkering. With my Christmas money I decided to finally buy a Haynes manual for the scoot. It won't start when it's cold unless I put a rag in the air box to block it up, guessing this was an auto choke problem, ordered one and going to fit it tonight. Going back to the carb problem and stalling, it still stalls, although it rides perfectly it won't idle. As soon as I slow down to a stop it dies out. (Hot or cold engine) I've tried the screw all the way in, all the way out, even put the fuel mixture screw to 1 and 1/4 turns like it says in the Haynes.
