well I would like to buy this http://www.pedparts.co.uk/product/94/polini-air-filter-37mm-covered air filter, but I dont know what jets I should use? Currently I have everything stock apart from a leo vince exhaust. also is it easy to upjet my scooter? thanks for your time Nathan Keen
Do you have the jeting kit ? i mean different jets ? best thing for stock carb is to get a set so that you don;t have to buy separately in the future, all you do is unscrew the carb from the manifold and unscrew the 4 screws on the bottom of the carb and unscrew the gold screw with the number on it, when you are ready screw everything back and make sure the carb is straight
thanks for the good replys I bought this air filter the overday (it arrived today) http://www.pedparts.co.uk/product/727/stage6-double-layer-air-filter is it worth putting it on and seeing if it runs fine or would you jet it up first ( or if anyone knows what jet runs best with this air filter!) kind regards Nathan
If you put that on there @ run your scoot without upjetting - you will seize the engine. You need to upjet by about 30 points or more and then work down. This requires lots of jets and patience. If you're short on either - don't bother. Good luck
