hi ive got a metal x 100cc (same as the speedfighter) i need some help with basically the bike has had a new cylinder and piston as exhaust studs snapped so thought it was best to change all of it then its aslo had a new .carb with manual choke .reeds .rear suspension .throttle cable .spark plug .gaskets all round .open air filter .new fuel and vacuum lines .new vacuum fuel tap .ive checked all wiring for eny loose ore corroded connections .new rollersand belt the problem with this bike is it takes forever to get it started once its warm it will start every time its also had a problem lately where you will be riding along and the bike will just turn off at around 50mph when slowing down ore exiting a dual carriage way after this it is very hard to start and most of the time wont start the piston and rings have been checked and they are fine ive replaced every think that's not to expensive and now I'm stuck at what to look at next eny help would be much appreciated thanks
