Peugeot Looxor 100 wiring diagram or oil level warning knowledge?
Discussion in 'The Workshop' started by freddeboy, Oct 8, 2024.
  1. freddeboy
    freddeboy New Member
    Hi!
    I have a problem with my Peugeot Looxor 100 cc 2003. There is no way to know if the oil level warning light is functional or not. The owners manual does not mention anything about this. I have tested the oil level floater mechanism and all the wiring including the bulb and everything is okay. It fires up the light when the floater reaches the bottom of the oil tank. But how do I make sure that the bulb is functional on next startup?
    I have tried to apply the wiring diagram of Peugeot Speedfight 100 since it's the same engine and CDI unit. Most of the colors of the wires are exactly the same but my Looxor seems to be missing the lamp check on ignition on (or when starter is operated). I think the 12 volts for bulb check purpose is added in the instrumention dash on the Speedfight.
    Can anybody shed some light on this or maybe supply the wiring diagram for Looxor 50/100?
    Did Peugeot "forget" to supply this function on the Looxors?
    Thanks!
    Fredrik
  2. MARSH
    Is it a 2t or 4t engine ?
  3. freddeboy
    A 2t.
