Peugeot blaster water pump
Discussion in 'The Workshop' started by Dibs74, Mar 13, 2017.
  1. Dibs74
    Dibs74 New Member
    Hi , can someone please help with changing the water pump ? Mines starting to rattle a little, do I need to drain the water before I undo the bolts, also can you buy after market ones like stage 6 make for Yamaha, can't find muck information about it anywhere, many thanks
  2. Dibs74
    Dibs74 New Member
    Think the blaster is out dated no one know anything about them, thanks ill look on another site ,
  3. Tamiyacowboy
    Tamiyacowboy Pippa's Owner
    Piaggio Skipper
    whoa there Dibs
    first off yes you MUST drain the coolant from the negine before removing the pump system .
    as for removal the very best place for this is your good old Peugeot blaster ludix manual by Haynes , fully documented with images to help new and pro builders maintain there rides.
    ( i own a haynes for my scoot and its a god send ;) well worth the £20 price )
  4. Buzz
    Buzz Active Member
    I cant see any value in a stage 6 racing water pump, it does what it says and pumps water. Any cheap after market replacement will do the job. When i say cheap you wont get much change from £90 if you buy new. Ive never tried repairing a blaster pump. Drain the radiators so the system is empty, remove the pipes from the pump and take the whole unit off. Open it up and try to see why its rattling.
  5. Dibs74
    Dibs74 New Member
    Cheer for all ya help guys, gona get manual today from eBay
