Petrol
Discussion in 'General Scooter Discussion' started by The General, Oct 3, 2007.
  1. The General
    The General Member
    Hi my typhoon 50 only did 27 miles on a full tank wtf?! It was running out quickly before I had my parts fitted (exhaust, cylinder kit etc) but this is just a piss take.
    It seems to be fine but then I turn it off leave it for a while and the fuel guage is in a completely differnt place. I have checked my ground for a leak the night after but theres nothing.
    Any Suggestions?
    :wtf:
  2. kyle1b1
    well you have just put a sport kit on and a laser x pro. and you wll have upjetted quiye a bit so is defo going to use more fuel but that seems abit low. dosent help going full knacker everywhere like i do :pimp: which drinks petrol like twat :w00t:
  3. The General
    The General Member
    I know thats what i added the disclaimer at the start but surely it shouldnt b anywhere near that low?
  4. skatergod
    skatergod New Member
    lol i wheelie all the time on my typh 125 and go full wack most the time and i get at least 60 miles for a full tank mabe 70
  5. kyle1b1
    you sure it jetted right not running rich which will use more fuel then than need ? what main jet you got him? is a del 17.5 right ?
  6. The General
    The General Member
    I'm running a 72 jet at the moment:
    53 standard
    Pipe
    Carb
    = 72 jet (is this too high? seems to be running alright like this)
    Now I need to add my polini air filter what should I go up to guys?
  7. The General
    The General Member
    B.t.w the reason im running a 72 is because my bike was bogging out past half throttle with a 68 main jet. I have drilled a load of holes in my airbox though because it wasn't getting enough air but now it is since ive drilled the holes with the 72 jet.
  8. kyle1b1
    well mine with a del 17.5 was a standard 56 and was running a 67 with malossi sport bore and leo vince tt. u checked the jetting ?
  9. MiNoR cOnFuSiOn
    if it dies out try lighter rollers first.
  10. The General
    The General Member
    If what dies out?
    It doesn't die out my bikes running well just rinsing petrol?
  11. MiNoR cOnFuSiOn
    when you upjetted from 67 up to a 72. if the engine dies out try lighter rollers then check the plug if you think its right. start high and get it rollerd right then work the jet down till the plugs white at full throttle warm. then go up one or two. check the fuel tap isnt jammed open aswell as the fuel will run out the carb and evaporate befor morning. float might be wrong or the fuel tank could even have a shit fitting somwhere letting it all run out (125 typhs second tank bottom pipe fitting is the worst for this) ether way the recorded mialage is not right for the fuel so theres somthing wrong, or your speedo's wrong an your driving it further than you think (joking)
  12. The General
    The General Member
    but why would it be the rollers if its running fine now? and also ive gotta add an air filter so what should i go up to now guys
  13. MiNoR cOnFuSiOn
    72 is usually fine for a filter. so making it rich has cured a roller problem and given you incredibly large ammounts of fuel usage. just try it
  14. The General
    The General Member
    What roller size do u suggest?
    I've got 5gs in at the mo
  15. J-Nitro
    J-Nitro Active Member
    try something between 4 - 4.5grams for a laser
    the laser is an incredibly high revving pipe the revviest ive seen yet so for maximum performance you need a little lighter rollers, i prefer 4.1 grams rather than 3.4 or 4.9, but you do have a different motor and a different engine size,
    4 grams would be worth a shot
  16. Goodship1002
    Goodship1002 New Member
    Sure your fuel gauge just isnt a bit naff?
    Check the tank next time. Gauges are crap.
  17. The General
    The General Member
    I'm gonna get some 4g rollers tomorrow but I dont see how its going to make me use less petrol when my bike is running perfectly atm just using ALOT of petrol.
    :msn1:
  18. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    i hav the same prob on my stalker, it was a tiny leak just as it connects to the carb, not much came out so it didn't look as if it was leaking because it evapourated before it got to the floor.
  19. Purplepill
    Purplepill Member
    I think with lighter rollers you may find it wont bog with a lower main jet, meaning at the mo your running to rich so look at your plug?
  20. Sw1fT
    Sw1fT Active Member
    200SX S13
    but if you go too light on the rollers you're gonna use more fuel, coz it will rev higher and so use more fuel.
