Petrol Leak
Discussion in 'The Workshop' started by Duggiedan, Mar 20, 2012.
  1. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    Hey guys having problem with my scooter put new air filter on bike, changed jet and obviously being a tit i over tightened screw on float bowl and cracked corner causing too leak so i used this speak glue to bodge together and worked and still leaking but now it seems the bowl isnt sealing properly here vid of how bad leak shows at end
  2. Duggiedan
    Piaggio Zip
    forgot to mention would i be able to make a gasket to seal parts together would this stop leaking?
  3. roxy boy
    roxy boy Well-Known Member
    roxi
    probs not as the petrol will disolve it ....i would get a mallosi 1 for £15 and you dont have to take the float bowl apart to change jet it just unscrews and is also see through....look on mallosi site or ask psn to order u 1 in ...av got 1 on order
  4. Duggiedan
    Piaggio Zip
    Cheers callum Ill have a look could do will one of them handy instead of taking full thing off could you send link for that float bowl?
  5. ramo
    ramo GoldMember
    Malossi is only for the 25 and 28?
    If you cracked the bowl it will more than likely never seal properly
  6. Duggiedan
    Piaggio Zip
  7. roxy boy
    roxi
    From tht place in Germany they do em ..don't av link cos am on ma phone
  8. ramo
    ramo GoldMember
    That is news to me i thought they only did them in PHBL and PHBG flavour. They do 21mm PHBGs but theyre the (expensive) black race ones
  9. Stathis
    Nrg Power 70cc
    try to find from a dumped scooter or something ;) doesnt worth giving 10 quid for a freaking box!
  10. Duggiedan
    Piaggio Zip
    i got a new float bowl off pm tuning it came and decided to still leak so i went and got some blue gasket sealer and stopped the leak :D got it all set up and now cut out and wont start :( if you can help check the workshop area
  11. roxy boy
    roxi
    Who set it up ..and u checked all the ovbs things
  12. Duggiedan
    Piaggio Zip
    psn mate
