performance exhaust issue HELP!
Discussion in 'Newbie Scooter Tuning' started by Chaarz, Oct 2, 2013.
  1. Chaarz
    Chaarz New Member
    I just recently bought and installed a pedmoto series 1 exhaust and the 4 gram rollers it came with now my moped takes a while to engage and take off from a stop its dangerous at roundabouts any help would be nice oh and my bikes a 2004 aprilia sr50 ditech fuel injected so it doesent use a carb cheers.
  2. Chaarz
    Chaarz New Member
    yeah it doesn't even move then :L
  3. Chaarz
    Chaarz New Member
    i need serious answers not another troll grow up.
  4. MARSH
    You might need to try a few more roller weight's to find out what work's for you, are you big boned or 7 stone wringing wet? Trying different weight's and use what work's. Is your scooter de-restricted? And yes this is another serious answer!
  5. Nathanael
    Nathanael Active Member
    did you fit stiffer clutch springs when you chnged the exhaust?
  6. Chaarz
    Chaarz New Member
    No i dident fit different clutch springs thats what im going to try tomorrow when i can get some ! hopefully will sort my problem out, and marsh i only used what came with the exhaust which was 4 gram and i think standard was 7 gram i dont think its the rollers sounds like the springs but im not sure its doing my head in lol
  7. Nathanael
    definately springs,
  8. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    The roller weights are probably too low and take too long to start changing the variator try about 5.5 and don't mess with the clutch springs until you try heavier weights.
