Hi guys, im thinking about painting my plastic panels on my nrg e.g the footboard and the plastic around ignition and under seat, but im just afraid will it chip off ? and look tacky as, or is there anything i could do to stop it from flaking/chipping off cheers
make sure you use plastic primer , plus if its the rough plastics, you could always use a a filler primer aswell and sand that back till its smooth, top coats, then laquer, shouldnt flake at all imp:
Ok Cheers Di, Plastic primer is supposed to be white correct ? as bought 1 tin and shaked it obv then sprayed and it came out in a clear spray like laquer ? took it back they said this is right as has the code stamped on tin, yet got another one replaced it and is the same ? Dodgy batch maybe ? arc:
no plastic primer is clear and filler primer is a white/baige colour i think but plastic primer is defo clear
For mine I used a plastic primer and it was clear just like laquer, its just a base for the other paints to stick to so don't worry about what colour it comes out like
