i know this disc is 10 inches. And my wheel is only 12 inches. But will it fit my Runner 125SP? What will i have to change? Thanks. http://scooter-center.com/catalog/produ ... 5_174_1303
no i rekon it will be ok as i know nrg wheel fits on a runner 125 with disc etc and the runner 50 discs and brake are the same so therefore it should fit the 125 runner
you need 50 forks to use this or any 280mm disc.. the 125 caliper mounts are 10mm further apart. if you can have a diff adaptor made it will work fine tho. just 2 samwedged plates should do but a cnc milled bracket would be tidyer
