Hi All, I'm having trouble trying to solve an overheating problem, I have checked the fan and the thermostat both appear to be working ok, the water pump also seems to be operating correctly, does anyone have any other suggestions that I could try.
You could take the radiator off and check that it's not blocked up with rust or anything. I guess you have bleeded the air out the system and used the correct mixture of coolant first ? Does it have a temperature gauge or just a warning light ?
If you havnt sortet it out check it out here: https://www.oemmotorparts.com/oem5.asp?M=Peugeot&T=ELYSEO 125-150 - 125 cc&Y=2001&L=PE-ELYSEO_125-150&O=COOLING SYSTEM&F=PE-ELYSEO_125-150-AY&L2=PE-ELYSEO_125-150-AY
