Original or Sport Crank?
Discussion in 'Scooter Tuning' started by alex8r, Nov 22, 2008.
  1. alex8r
    alex8r New Member
    Just bought a Metrakit Handmade 70 :p , just wondering whether I will be needing a sport crank for the kit, it's bhp on the dyno is 8.5-11bhp. I heard that anything above 12,000rpm is dangerous to a standard crank so im hoping it doesn't rev much above that. So will I need a new crank or not? My old one is in average used condition
    Cheers
  2. capri dave
    capri dave Active Member
    The thing is when you fit any 70 kit it will cause your main bearings and crank
    to wear out faster...
    Even a polini cast iron which produces its power at quite low revs will wear out a std crank and bearings quicker ;)
    buy a sport crank and a good quality set of bearings before you add a 70 kit,
    its better to take your engine apart once and do a proper job the 1st time!!
  3. pimped_aerox2
    pimped_aerox2 New Member
    cant remember what year your ped is m8 but standard should be fine and i dout its gunna rev over 12,000 tbh unless you just have stuiped rollers think of phils ped on a stardard crank and how high his revvs are.
  4. Sw1fT
    Sw1fT Active Member
    200SX S13
    shit advice once again....
    do as dave said, the crank is the most expensive part to replace, so its worth doing before it takes out any other parts. It's not just rpm which causes a crank to fail, and as dave has said, its not just the crank which can fail, higher capacitiy engine with more power is going to stress the crank and bearings much harder, causing them to wear faster.
  5. alex8r
    alex8r New Member
    Cheers for all the advise so far, due to money restrictions if its not completely necessary just yet to buy a new crank im gonna try and avoid it, this not necessarily being sensible. I'll have to have a look at some sorta cheapy sport cranks or something :rofl:
    Edit--BTW Pimped Aerox it's a 2001 ;)
  6. capri dave
    The BGM cranks are good value for the money ;)
    I got 1 in mine :D
  7. alex8r
    alex8r New Member
    Cheers dave, chances are they wont sell the BGM one's for my bike, they dont sell alot of products for it really haha. But i'll have a look around..
  8. MiNoR cOnFuSiOn
    look pimped aerox.. its against the rules and qujite frankly PISSES ME OFF when YOU of all people try give advice.. just fuck off. like REALLY
  9. alex8r
    alex8r New Member
