After plenty research I realise there are many ways to skin a cat on this one. If one fits the bearings to the crankcase halves first then fits the crankshaft to the bearings. Can I fit crankshaft seals after the crankshaft is fitted as to avoid the possibility of overheating them? How much heat can the seals actually take? Oven temp at say 120ÂșC? I have seen lots of tutorials and videos on fitting the crankshaft and bearings in various orders, but have noticed that they always have no crankshaft seal. I do not know if this is only demo or fitted later. My Haynes manual states fit the crankshaft seals, the bearing to the crank and then to crankcases.
I heat the cases up with a blow torch then push the bearings in, then heat up the centre of the bearings and put the crank in, after I've centralised the crank I let it cool down, then I put the seals in.
