Oil sump nut socket / spanner size ?
Discussion in 'The Workshop' started by Psycho, Mar 2, 2013.
  1. Psycho
    Psycho Member
    Gilera DNA 125cc
    Anyone know what size of socket / spanner fits the sump nut on a Gilera DNA 125?
    I know its bigger than a 22mm and smaller than a 32mm.
    Need to buy one to fit and dont wana have to buy a whole set for one socket / spanner.
  2. MARSH
    It's 24 mm, don't over tighten when you refit it!
    Psycho likes this.
  3. Psycho
    Psycho Member
    Gilera DNA 125cc
    Cheers man, borrowed a socket set off a guy in work and figured it out.
  4. Psycho
    Psycho Member
    Gilera DNA 125cc
    Any suggestions on how to get the oil filter off?
    Cant find a tool in my box that comes close to the size of the slot on the front.
  5. MARSH
    I use pipe grips, swan neck pliers, whatever you want to call them. When you refit new filter, fill it with new oil (5-40) fully synthetic engine oil. Only fit it hand tight and I fit a jubilee clip round the filter and butt it up to the engine case so it can't unscrew!
  6. Psycho
    Psycho Member
    Gilera DNA 125cc
    Cheers man.
    Havent got any swan neck pliers, ill invest in a set tomorow.
    Yea Im used to changing them on cars so I normally just hand tighten them. With all the car ones ive replaced though its had a hex end on it for putting a socket or spanner over, this one has some wierd screwdriver shaped slot which Im not used to.
    Cant see any way of fitting a jubilee clip on it though, not with the shape of the mounting area.
